Volvo V40 2001 Timing belt installation!!!????
Old 10-27-2007, 11:29 AM
Speedy84's Avatar
Default Volvo V40 2001 Timing belt installation!!!????
Hi everybody ,
Like a first timer I will need your help . My V40 2001 1.9T needs the timing belt to be changed . But I don't have the positions gage . If someone have a picture of how to instal it or explain me the positions it will be apreciate . Thank u
Old 10-27-2007, 12:23 PM
Default RE: Volvo V40 2001 Timing belt installation!!!????
The top cover is the timing marks and the others are on the pulleys.
http://www.babcox.com/editorial/ic/ic60326.htm
This site might help a little.
Old 10-27-2007, 05:08 PM
Speedy84's Avatar
Thank you very much ... The timing belt is already cracked and when i,m on Drive(automatic transmission) at a stop sign the engine die andwhen i restart the car it start rightaway ...i changed the alternator , and it still does it... than i realized that the timing is cracked and may skip on gears . Hope is that .... Thanx again cause even Volvo could not find the problem .....VOLVO CANADA lol
Old 11-07-2007, 10:19 PM
timing belt rarely skips in S40/V40 with the 1.9T but replacing timing belt will need u jack up engine and remove the mount on side of engine also r/f tire have to come off. mostly when not idling is IAC motor. hope this help
andoras1977
02-05-2014 02:50 AM
NHVolvoMan
09-22-2011 12:57 PM
russellsv40
06-02-2011 12:02 PM
yank50
03-01-2009 08:59 PM
Johnboy
12-11-2008 07:35 AM
Quick Reply: Volvo V40 2001 Timing belt installation!!!????
