Fuel pressure regulator
Old 10-31-2007, 11:12 AM
rick123's Avatar
Default Fuel pressure regulator
can anyone give me a web page to ordera fuel pressure regulator
thank you
Old 10-31-2007, 10:43 PM
rick123's Avatar
Default RE: Fuel pressure regulator
Sorry please allow me to properly introduce myself that first post was written on the way out of class so it was rushed. My name is rick as you can see from my account name. I own a 2000 S40 and have recently stumbled upon this website when searchin for a hole in my firewall to install sub-woofers. After looking around i notice that MANY S40's have starting and almost all of them around here have been related to problems with the fuel pressure regulator so I am trying to look into it but i can't find any websites that have the part specific for a volvo s40 so any help would be greatly appreciated.
Thanks!
Old 10-31-2007, 11:08 PM
01_fast_ride's Avatar
Hi Rick, welcome to the forum. At the top of the S40 forum is a thread named Volvo Resouces Thread. There you will find a wealth of info. As for your specific question locating fuel pressure regulators, I checked check two of my favorite spots really quick and came up with this:
http://www.eeuroparts.com/productdet...&code=9605
http://catalog.worldpac.com/fcpgroto...sure+Regulator
The first link has the better price for this item and offers free shipping as well.
Old 10-31-2007, 11:23 PM
rick123's Avatar
Hey thank you very much D1 I appreciate your help, now lets just hope that I can get my car to start without haveing to crank it more than once or without holding the key for longer than 5 seconds!
Old 11-03-2007, 10:13 PM
Hudini's Avatar
I just fixed this very same problem in my 2001 S40. It was the FPR as you suspect. However, when removing the rubber elbow to the vacuum line, I noticed it was split. Now was it split before I pulled on it to put the new FPR on? Or was that the problem to begin with? I don't know but might be worth looking at your car before you spend that $86. Rubber vacuum hose is ALLOT cheaper.
BTW: My local dealer had the FPR for $96 plus tax which makes the $86 look pretty good.
Old 11-05-2007, 10:32 AM
rick123's Avatar
hey thanks hudini ill definately check that out before i go ahead and buy the new FPR
Old 11-14-2007, 10:54 AM
Hudini's Avatar
Did you fix your problem?
Old 11-17-2007, 02:25 PM
hey.. um where the hell would rubber elbow be to the vacuum line be located at? lol and umm.. where would the fpr be located at also?... im kinda new to this car stuff so yea im a newb
Old 11-17-2007, 02:49 PM
The elbow comes off the regulator.
The regulator is under the throttle cover on the end of the fuel rail.
Old 11-20-2007, 11:46 AM
Hudini's Avatar
Stole this from Andy. The red circle is where the fuel line connects to the fuel pressure regulator. The FPR is the black plastic piece that is held to the end of the fuel rail by one bolt. The rubber elbow connects to the vacuum source and is just out of the picture below the FPR. As said above, this is covered with a black plastic piece.
Old 09-30-2008, 10:17 AM
costa993's Avatar
hey Hudini, how did you get the fpr for $96 + tax? Everywhere I check it's about $200........Thanks.
Old 11-11-2008, 01:10 PM
Hudini's Avatar
What a difference a year makes. They USED TO BE $96. Over $200 now. Wow. We must have bought all the ones they had in stock since this seems to be a common problem with this engine.
Old 08-04-2009, 12:44 AM
shogunkicker's Avatar
Hey guys, I have V40 and just had this happen to me. Though it was not the regulator, just the hose. It has a huge gash on it before it curves down into the motor. Now, Do I need to buy the whole thing or just the hose? thank you!
Old 08-04-2009, 12:49 AM
850tony's Avatar
if it is indeed just the hose, that is all you need to replace. if the hose drips fuel after it sits for a bit, then you need to replace the fpr.
thanks for searching on this topic first.
Old 08-04-2009, 01:53 PM
oh yeah, i needed to know what the hell i was talking about before i opened my mouth in here. hehe
so ok, would that be considered the fuel pressure regulator vacuum hose? there is a dealer down the street and i just wanna know what im talking about, before i confuse them and sound like a newbie!
thanks
Old 08-15-2009, 08:20 AM
mk_s40's Avatar
Hey guys, i am having the same problem with my fuel pressure regulator except my car is the 98' model s40 but this is turbo (2.0t). Does the location shown on the previous page with the picture along with the red circle showing the FPT also apply to my car?
Old 08-25-2009, 09:14 PM
ricky's Avatar
hi, my 02' S40 has the long starting problem, but i didn't see any fuel in the vacuum hose.
Do you have any progress, and do you know where to buy just only the vacuum hose, not the whole fuel pressure regulator ? if it can be got easily, I want to have it replaced first.
Thanks!
Old 08-29-2009, 03:33 PM
Lyonsroar's Avatar
Have you joined s40concepts.net/forum?
They are so helpful and most often you get a reply in less than 24 hours.
Old 05-29-2010, 08:10 PM
jimboy's Avatar
I have an 05 v50 with same slow to start problem. Keep looking for fuel pressure regulator and can not find anything. I did find a part called fuel pressure sensor, same difference? Thanks
Old 11-17-2010, 10:39 AM
barwick11's Avatar
I just bought a 2000 S40 and it's doing the same thing I presume, put it to the floor for a sec while cranking and it'll start up fine, but otherwise it's craaaaaaaaaaaaaaank....
Holy crap, over $200 for this stupid part? I could buy an aftermarket racing regulator for that much, tap the fuel rail, and have someone custom install it for less than that.
Quick Reply: Fuel pressure regulator
