removing interior door panel?
I need to replace a broken door handle on drivers side door. Anything special when I go to remove interior door panel to acces linkage??? does it just pull out after removing 3 visible screws??? anybody know of another supplier for handle other than dealer?
RE: removing interior door panel?
I'm assuming you mean the exterior handle on the outside of the door? There is a screw in the compartment where you put your hand to pull the door closed, a screw where the inside handle release is located, and I belive there is one more on the face of the door panel. It's a good idea to put the window down just about a half inch to relieve the stress on the door panel. Don't put it down too far or you will not be able to unbolt the outside handle when you have the door panel off and the glass is in the way. Next note: There are several snaps holding the door panel to the metal of the door. Start at the bottom and work your way up as you pull. Easy as you go since these snaps are plastic and they do tendto break.The top of the panel is probably looped over the metal of the door so you will have to wiggle the panel up once all the snaps are off. I have an S40 but have only done this on the S60 so I'm only partially helping here. Now getting to the outside handle might be tricky given all metal that is in that door. Becareful when you are removing the bolts on the metal of the door now that the panel is off (which ever bolts you might have to remove) some of them hold the window regulator to the door and you can easily knock the window off the track. Now I have heard of a problem with the door actuator going bad and you were unable to open the door from the inside. Good luck I'll check back shortly.
the cardboard insullation configuration
So I had to remove the front passenger side door panel because my wife's wedding ring fell into the door b/c there was a crack in the little coin tray above the door handle. *sigh
I've had to remove the door panel of my 2000 IV jetta, and let me tell you, this one was sooo much easier to remove.
Besides the three obvious screws, there are three others. If you open the door and are looking at it from the inside, 2 of them are on the right hand side on the outside edge, and one of them is behind the speaker cover.
After removing the screws, the panel pulls towards you from bottom going up, and after getting the door handle free from the panel, you should be able to lift the panel up and off the little track and free from the door lock.
Now that's the easy part. I was focused on finding the ring (which I found thank God) and I wasn't paying attention to how the stupid cardboard peices fit in there between the metal door and this panel. They're supposed to be glued, but, mine had come free.
I'll try and figure out how they go on there, and post a picture if I get it figured out. Otherwise if you're about to do this, take a picture for us. I may end up just leaving them out all together as I've got to this done in a hurry.
xxscorpion
01-17-2014 10:59 AM
