Door module S60
Old 01-20-2008, 09:40 AM
bealschapel's Avatar
Default Door module S60
HELP PLEASE??? 2001 S60 door lock, window, everything dead, and taken over by ghosts that try to lock and unlock the door after it's off. I'm pretty sure it's the module but don't know how it comes out. I can get it up about three inches, but can't reach the plugs to get it out. Does the door panel have to come off and if so, how?[]
Old 01-20-2008, 09:43 AM
Default RE: Door module S60
The door panel have to come off.
There is clips around the bottom and mid section.
Also the handle you pull to close the door the outer cover pulls off to gain access to 2 screws.
But when you unplug the door module it will keep th einterior lights on all the time and eventually kill the battery.
Old 01-20-2008, 09:52 AM
it would be best to take it to a qualified volvo technician who has the proper tool,s you can cause dammageto door panel and electronics
Old 01-20-2008, 06:47 PM
JPN's Avatar
JPN
JPN is offline
Tech, I have moved this from New Members Area. Notified the original poster.
JPN
Old 01-20-2008, 07:44 PM
ORIGINAL: JPN
JPN
Sorry I missed it was in the wrong section.
Old 01-21-2008, 09:13 AM
2002v70's Avatar
ORIGINAL: jlsolid66
Taking it to a Volvo dealer causes significant damage to your wallet. The purpose of all these discussions is to try and avoid dealer induced financial damage.
The door panel removal is not beyond anyone that can change their own oil.
Old 01-30-2008, 07:34 PM
Now what???? just replaced with brand new Volvo module but it is not reacting at all. I read somewhere that the module may have to be "turned on" by the dealer??? I have a cheap set of door panel removal tools bought at Harbor Freight for about $3 and one hour to totally replace the unit, no problem. Any ideas how to activate? I have already cycled the key on and off and disconnected the battery.
Old 01-30-2008, 09:19 PM
Yes you have to take it to the Dealer so they can download software to make it work.
Old 01-31-2008, 08:57 AM
2002v70's Avatar
When mine went, I tookthe whole switch assembly apart to see what the problem was. With mymine the problem was the contacts between thecircuit board and the buttons were just dirty. I sprayed the whole board with contact cleaner and it now works fine. Also, since it is the original unit installed, there is no reprogramming at the stealership.
Chris 850T
10-16-2011 09:22 AM
cordoba
05-15-2011 06:15 PM
cordoba
02-09-2010 12:50 PM
cordoba
12-21-2009 06:01 PM
Quick Reply: Door module S60
