Whining noise
Old 01-23-2008, 06:12 PM
vetalbig's Avatar
Default Whining noise
After cold start this morning I have noticed a wining noise in timingbelt area, it is hard to say though where it isexactly coming from but it’s definitely on a left side of the engine. Once car wormed up a little bit it was gone, I let it cool off and the same noise came up again when i started it. I have changed timing belt this summer but I haven’t touched anything else there. Any idea what it is?
Old 01-23-2008, 06:23 PM
Default RE: Wining noise
Most likely a bad tensioner or idler pulley. (timing belt)
Old 01-23-2008, 06:41 PM
vetalbig's Avatar
yeah i would think that is tensioner because i was messing with it couple of times by compressing it with clamp .
how soon it should bereplaced or can i still run on it for a little bit?
Old 01-24-2008, 05:43 PM
It has got to be one of the pulley's not the hydrolic part itself.
I would replace as soon as you can if it comes apart you will be looking at about 3k for the repair.
Old 01-25-2008, 08:38 AM
Psaboic's Avatar
When it is cold out, our 850 has a groan/moan sound that is RPM dependent from the timing belt area. It lasts for about 30 sec or so then goes away. I ahve used belt dressing and it seems to help. Just my .02
Old 01-25-2008, 11:37 PM
vetalbig's Avatar
how hard is pulley replacement procedure?
is there anyspecial tools needed, or can i justwork it with aregular tools?
Thank you!
Old 01-26-2008, 08:58 AM
It is like replacing the timing belt.
One is held on with 2 12MM bolts the other is held in with a T-45 I believe or a T-40.
I bought one and cut it down some to fit properly.
cetaphil
03-23-2009 08:27 PM
gdstuart
07-22-2007 03:40 AM
2006S60R
07-07-2007 10:11 AM
johnhon
10-21-2006 07:27 PM
conoros
09-27-2006 06:50 PM
Quick Reply: Whining noise
