Exhaust temperature question.
I'm wondering how hot the exhaust air should be out of the tail pipe after a long drive at normal freeway speeds of 60-70mph. I drove ~150 one way, 300 total in the day (car was off for 10+ hours inbetween) all in 'economy' and w/ very moderate acceleration and while my car was idleing when I got home and was removing everything from the wagon I noticed the exhaust air was very hot, it would definetly burn you if you touched the pipe.... is that anything to worry about?
RE: Exhaust temperature question.
ORIGINAL: oldvovo
The normal exhaust gas temperature (EGT) of a N/A engine is somewhere around between 700-750C (and probably another 100C+ higher if the engine is running lean) while the EGT of a turbo engine could be as high as 900C, depending on how hard the vehicle has been driven. Also keep in mind the internal working temperature of the catalytic converter is well over 1000C.
A portion of all that heat is absorbed by the metal exhaust system and consequently it does not surprise me your exhaust pipe was hot enough to burn you after a 150 mile drive.
ORIGINAL: Psaboic
It still wouldn't hurt to take a quick look at the converter after a semi long drive, but I think you are ok
A quick look at the converter would be just that - a quick look at the converter or are you suggesting oldvovo should look for any signs of the converter being physically damaged or burnt through?
I remembered that one member said his cat was physically "red-hot". I myself have never heard the spent gas being so hot but as multiple members say it is ok, it probably is a normal condition for the 850. However, theoretically the spent gas on turbo engine should not be that hot, as the heat and pressure is used to turn the turbine in the turbocharger (160,000 plus/minus RPM). However, after a long drive and the engine at idle (turbocharger not in use) it could be a normal phenomenon. I need to study further[8D].
JPN
JPN
turbowagon94850305
07-31-2010 10:48 PM
Fluxmotoring
11-18-2008 02:53 PM
