Sponsored by:
Sponsored by: DashLynx
Windshield Wiper replacement
Old 03-22-2008, 12:36 PM
9Iron's Avatar
Default Windshield Wiper replacement
I need to replace my windshield wipers but apparently it is a different configuration than i have ever changed before. Every other vehicle I have owned had either a hook or push the ball through the hole method. I went to an auto parts store and he said it must be a specialty thing that i have to order through Volvo. Is this true or did he just want to be rid of me? Kind of humbling going to do something as simple as replacing my blades and being stumped like this! Thanks in advance for any help.
Old 03-22-2008, 01:23 PM
S60 R's Avatar
Default RE: Windshield Wiper replacement
I had the same problem, I figured they were just like every other kind. There are tabs on oth sidesnear the end of the wiper arm. Hold both tabs in and the part of the blade that faces the driver's door kind of slides out first, then the blade slides out.Once you do it, it makes sense.
I went to the dealer for a replacement set. They might be a little more, but at least you know they will fit right.
Old 03-22-2008, 06:21 PM
djgiovanni's Avatar
I bought replacement refills from Bosch. The old ones I distroyed taking them out (literally). To insert the refills, on the blade holder, if you will, still attached, i opened the two tabs on the very end, and just fed the refills right in. Then with plyers I squezed the two tabs shut, and I was done. The first one took me about 15 minutes. The second one no more than 1.
Old 03-23-2008, 12:26 PM
abercrombie9701's Avatar
i just replaced mine with the rain x blades. it took me 10 mins and cost under 20 bucks.
Old 03-23-2008, 07:48 PM
I just went and bought some rain x blades myself, I couldn't really figure it out. So I gave up and put the old ones back on for now. The way they come, the wiper doesnt fit on the j-hook. There is some sort of adapter piece that it came with, but I was only expecting to spend a feew seconds with it; I had someplace to be.
What is it that you did to make it work?
Until later,
Nas
Old 03-23-2008, 08:32 PM
Yeah I am having problems with the passenger side wiper myself. I replaced the driver side but can't even get the old one off from the passenger side.
Old 03-24-2008, 07:31 PM
you have to put that other piece inthe wiper and clip the wiper onto the arm.its a little tough but i got it in
Old 03-27-2008, 05:05 PM
Fisher's Avatar
'05s and newer use the newer style blade that you cannot refill. I found a good price on them at:
http://vparts.dealerfit.com/store/prod126_24239.php
About the same price as aftermarket, but at least I know they will last2-3 years.
rspi
01-11-2014 06:22 PM
Dr.JellyFinger
12-17-2011 02:39 PM
mark_disfree
03-27-2009 11:13 PM
95pimpwagon
01-20-2006 01:09 PM
Mr. T
01-30-2005 03:17 PM
Quick Reply: Windshield Wiper replacement
