1991 240 How to install clutch flywheel correctly. Aligning with crank angle sensor
Old 04-27-2008, 11:11 AM
silly2bme's Avatar
Default 1991 240 How to install clutch flywheel correctly. Aligning with crank angle sensor
1991 240 5 speed trans with stepped flywheel. The flywheel didnt get marked when removed. It goes back on several different ways. But only one way is the right way. It needs to align with the crank angle sensor to start and run right. I found a procedure on All Data but its very confusing. It says there are two pins, pin A and pin B,that youneed to align with pin A 15 degrees below bla bla bla.Does anyone know how to align this darn flywheel?? Thanks, JIM[:@]
Old 04-27-2008, 11:21 AM
jonesg's Avatar
Default RE: 1991 240 How to install clutch flywheel correctly. Aligning with crank angle sensor
http://www.brickboard.com/FAQ/700-90...sionManual.htm
greenbooks
https://blarf.homeip.net/greenbook/gallery/list
https://blarf.homeip.net/greenbook/TP30868_2
hpanc
11-29-2014 07:19 AM
PTM76
10-08-2012 08:50 PM
volvoguy2323
06-24-2010 03:10 PM
rkolinski
01-13-2009 08:42 PM
silly2bme
04-22-2008 08:05 AM
Quick Reply: 1991 240 How to install clutch flywheel correctly. Aligning with crank angle sensor
