Car won't start, battery fine, hazard lights flashing?!?
Hi again!!
1996 850 Turbo
Car would not start a few days ago, so I jumped it and it was fine...nothing was left on.
Today the car will not start again, but jumping did not help. The car has been completely fine since the last time it would not start.
When I turned the key to start the car, it would not start, but the hazard lights started flashing, WITHOUT the hazard light button being depressed.
The battery tests fine.
I don't know much about cars. Any ideas?
Erick
1996 850 Turbo
Erick
RE: Car won't start, battery fine, hazard lights flashing?!?
Hey now,
I had the "alarm" problem once when on a date .
I used the fob to lock the doors but used the key on the passenger side, the chivalry thing, and as soon as I turned the key the lights and horn started going and all I could do was laugh [sm=smiley36.gif]. If it was going to happen, it was going to happen then. Date and all.
I had to go to the drivers side and use the key in the door to turn the alarm off then go back for a second try at the door for my date. Giggling all the way .
Glad it all worked out for you and didn't cost anything to fix.
[sm=icon_cheers.gif]
Replaced Volvo 850 95" w/ new battery..would not start. No spark in ignition coil..replaced coil, still will not start. checked distributor wires etc.good. Is this a computer glitch? Still no spark in the new coil..checked all fuses..good.
Bingo!
Had this same thing happen to me today with my 98 S70 GLT.
The car sat for about a year, jumped, drove 2 hours, ran fine.
Then I parked it at my new home, and it sat for another 3-4 months or so.
Today I picked up a new battery at Costco (HG48), that fits perfectly.
As soon as I connected both terminals, the alarm went off, and nothing will shut it up.
I have the key fobs, but both of them have dead , and I'm assuming that simply putting in new batteries won't be all it takes right?
Car won't start flashers flashing...
Battery is fine. My boyfriend had reached through the back door window to open it and let his dog out. When I got in, turned the key, nothing worked but the flashers. Read this post. Got out. Locked the car and then unlocked it. Got in. Turned the key... No flashers and the car started. Thank you for this post!
mrdude888
12-17-2010 06:56 AM
chrystald423
03-27-2010 08:05 AM
