boost pressure
Old 07-16-2008, 06:21 AM
robv70's Avatar
Default boost pressure
hi all what pressure should i see from a lpt v70 awd when given the berrys?
cheers rob
Old 07-16-2008, 07:27 AM
Default RE: boost pressure
5-7 PSI is normal for stock boost on an LPT.
Old 07-16-2008, 07:34 AM
robv70's Avatar
oops think i need a lower scale boost gauge then!
the on ei just got goes to 30 psi!!! hahahaha
rob
Old 07-16-2008, 08:10 AM
Your fine. You don't need to down grade.
I have an LPT and I have a 25 In Hg / 25 PSI gauge. But I have an ECU upgrade so I am pushing 15PSI right now.
Old 07-16-2008, 02:53 PM
s70 your pushing 15 psi with an lpt?
Old 07-16-2008, 06:26 PM
ORIGINAL: samadkins29
Yes and that is the highest you want to push on an LPT period.
Old 07-17-2008, 02:36 AM
robv70's Avatar
so would it be poss to wind a stock turbo open to say 10-11 psi? with no other mods? and safely?
if not can i put a normal t5 turbo on my engine with no reliability issues? and what pressure would a stock t5 turbo give?
rob
Old 07-17-2008, 07:42 AM
1. You can run 15 PSI on your OEM turbo with no problems. Now if that turbo is going bad or is already in bad shape then yes there can be problems. 10-12 PSI is a good boost in pressure and a nice noticable difference from 5-7 PSI. And it is safe if you go with an ECU upgrade.
2. You can put a T5 turbo on your car. But it isn't going to boot anymore pressure then what yours is now. Because your ECU is controlling the boost pressure. But a T5 turbo can handle more pressure better then your LPT turbo can.
Old 07-17-2008, 08:29 AM
JRL's Avatar
JRL
JRL is offline
"Standard" ECU chip will be around 12 lbs and is very nice and verynoticable
Old 07-17-2008, 06:22 PM
robv70's Avatar
ORIGINAL: JRL
sorry bud but what do you mean by standard ecu chip?
rob
Old 07-23-2008, 11:09 AM
He means the "standard" with respect to the tuning companies that actually have chips available for the Volvos. They are not really chips any more, but a soft loaded program, usually through the OBD port. Without this ECU tune, I'm reasonably positive the computer will cut out any additional boost you try to give it, such as with a boost controller (for anything newer than 1999.)
thecheat
09-22-2010 08:48 PM
turbo940v
09-03-2010 08:36 AM
endneu913
03-28-2010 11:41 PM
mygreenbomb
02-29-2008 06:09 PM
blkwgnt5r
03-10-2005 01:18 PM
Quick Reply: boost pressure
