Help ... power steering problem
Old 07-30-2008, 11:08 PM
Delirious's Avatar
Default Help ... power steering problem
very stiff steering, is it the pump or the rack?
how to test it?
Old 07-31-2008, 07:36 AM
Default RE: Help ... power steering problem
first check the fluid..always the first thing..
Old 07-31-2008, 02:37 PM
Dads850's Avatar
Dunno how to test, but on my 93, I had stiff steering for 2ish years, then developed a dead spot. Ended up replacing both the rack and pump.
Old 08-01-2008, 09:04 AM
Psaboic's Avatar
Definitely check the fluid level first. Actually I would go ahead and replace the fluid. Draw the old stuff out of the reservoir as much as you can with a turkey baster, refill, see what happens. If it is better, do the "draw out/refill/test 2 or three more times and you should have mostly fresh fluid in it.
Old 08-05-2008, 12:03 PM
Delirious's Avatar
1st thing I did was to check fluid level then replaced the power steering pump twice with veried results (used pump from wreckers). Now the question is are the pumps any good or is it the rack?
how to test it?
Old 08-05-2008, 05:47 PM
If you see fluid moving in the pump then the rack is bad.
Old 08-06-2008, 08:51 AM
Psaboic's Avatar
Yep.
Old 08-07-2008, 07:37 AM
if u turn and hear a "clunking"noise then its more than liekly the rack..
good luck
Old 02-05-2009, 07:49 PM
Delirious's Avatar
In case you are wondering I still have not got this stiff steering issue resolved, too damn cold right now to work on. However I have to get it on the road soon for my kids to drive the car.
As advised above I :
- checked the fluid
- there is no fluid movement in the reservoir
- belt is good
- replaced the steering pump with a junk yard one (hum .... yup I know!)
Before I get replacing another steering pump, should I check anything else?
thanks
Old 02-09-2009, 08:25 PM
Delirious's Avatar
Talking Got it!
Well ...it turns out it was a seized up steering knuckle! Lifted the car off the ground and greased it up, seams to have solved the problem.
rphud
01-08-2013 01:10 PM
earthbound741
02-28-2011 12:12 AM
rx7_guy
01-05-2009 07:57 AM
Cactus52
02-08-2006 07:57 PM
riccuk
09-12-2005 08:41 PM
Quick Reply: Help ... power steering problem
