ALTERNATOR 940
Old 10-04-2008, 08:20 AM
LESLIE's Avatar
Default ALTERNATOR 940
GREETINGS TO ALL FROM MOCA,PUERTO RICO. I RECENTLY PURCHASEDA 1995 940 N/TURBO AND HAVE A QUESTION CONCERNING
THE ALTERNATOR. THE DARNTHING WOULD NOT CHARGE IF THE LIGHTS AND OR THE A/C WERE TURNED ON.SINCETHE ITEM HAS
A LIFETIME GUARANTEEI GOT A REMANUFACTURED ONE BUT THE SAME THING OCCURS. IS THERE ANYTHING THE MECHANIC IS
MISSING OR IS IT THAT THE NEW ONE IS ALSO A BUMMER ? ANY SUGGESTIONS?
THANKS A BUNCH LESLIE
Old 10-04-2008, 04:31 PM
jsinton's Avatar
Default RE: ALTERNATOR 940
[align=left]How do you know it's not charging? Does the battery go dead?
A lot of times, when I have a problem like this, I'll go ahead and replace the battery at the same time as the alternator. How old is your battery? Do you know? If not, then just as a good measure, I would replace the battery too. Then you know your whole charging system is new.
[/align][align=right] [/align]
Old 10-04-2008, 04:36 PM
Check the Alt. gounding.
If the ground wire is messed up it will cause the same problem.
Old 10-05-2008, 08:08 AM
LESLIE's Avatar
jsinton& tech: okay on the battery. it's new(i believe 580 amps cold is the term). I'll check on the grounding although I think it's ok.
Hey guys thanks. It's unusual for a newly reconstructed alt. to be a lemon but ithappens. I'llhave thenext one checked before
it's mounted . Have a good one!
Leslie
Old 10-05-2008, 08:25 AM
LESLIE's Avatar
jsinton & tech: just thought of something that might help. The battery light does not come on so I had no idea that the alt. was
not charging. Does that info help? I had the car's battery and alt. testedfor performance and that's howI found the problem.
leslie
Old 10-05-2008, 08:45 AM
Alot of times the light will not come on a bad design from Volvo.
Old 10-09-2008, 07:42 AM
LESLIE's Avatar
jsinton,tech: I've narrowed the problem down to the regulator. w/o the A/C or headlights the reading for voltage is app. 13.5 v.
W/A/C on, the voltage drops.[&:] Leslie
Old 10-09-2008, 09:08 AM
jsinton's Avatar
You're still not telling us how you know it's not charging. Does the battery go dead?
The regulator is in the alternator.
[align=left] [/align]
winarabbit
09-12-2013 11:02 AM
dmathews
08-24-2013 01:27 AM
trout-19
03-28-2012 11:02 PM
Rapid Dog
07-19-2009 09:31 PM
tupapison
02-23-2006 12:28 AM
Quick Reply: ALTERNATOR 940
