P1550 code, any suggestions?
Old 10-23-2008, 06:30 AM
team's Avatar
Default P1550 code, any suggestions?
car is throwing a P1550 code, speed sensor, idle control etc. I believe all this is pointing back to the abs module which has gone bad. Will having the abs unit rebuilt fix this code?
Old 10-23-2008, 08:08 AM
BILL_MCCASSEY's Avatar
Default RE: P1550 code, any suggestions?
P1550 is code ECM-510F, vehicle speed signal. I would have it scanned with a volvo scanner before rebuilding the ABS module.There are other things that can trigger this code. It could be a signal too high, too low or lost all together. I don't know what type of scanner you used to pull the code, but you will see much much more with a volvo scanner.
Pubcha
11-26-2014 08:34 PM
Scott V
2001-2013 model year V70
02-08-2014 06:46 PM
alfords80
08-31-2009 06:49 PM
preese
06-06-2007 09:18 PM
oldvolvobrik
11-02-2006 06:21 AM
Quick Reply: P1550 code, any suggestions?
