S40 Blower Motor Resitor replacement
Old 01-07-2009, 10:03 AM
jack1564's Avatar
Default S40 Blower Motor Resitor replacement
I have Volvo S40, 2003. The blower in this is stuck at hight speed. I was told that it need to replace the "Blower Motor Resistor"
Where is this resistor located, how can Iaccess it ?
Old 01-09-2009, 03:04 PM
jack1564's Avatar
Default RE: S40 Blower Motor Resitor replacement
Any help ???
Old 01-09-2009, 03:47 PM
I thought someone was going to reply with the link like usual but they didn't.
There is a little black resistor under the dash. Remove the glovebox there is screws around when you open the glovebox.
Then remove the lower carpeted panel it is only a couple of clips.
The look along the metal bar that runs along the bottom of where the glovebox screws to. Just to the right of the center there is the black resistor. If I remember correctly you will need to loose the dash on the right side to get the resistor out.
Old 01-10-2009, 12:33 PM
Lyonsroar's Avatar
There is a how-to on s40concepts.net/forum as well!
JohnnyRocker
07-25-2014 02:34 PM
yert315
03-17-2013 08:59 PM
scott_boston
08-28-2011 02:17 PM
hohoho43
03-20-2008 12:00 PM
RPMCanes
01-02-2008 03:45 PM
Quick Reply: S40 Blower Motor Resitor replacement
