Rough ride, breaking and suspension problems
My 1996 Volvo 850T wagon drives roughly. There are a few things i noticed that could be related.
First, since I got the car 3 years ago I noticed it's low in the front. (is it suspension at fault? is so, what parts are first to check and replace and so on - to minimize cost).
Second, when i drive it i feel every bump or irregularity in the road and if i hit a pothole, forget it...it's like hitting my head against concrete...loud, hard and painful. The whole car seems like it's falling apart.
Third, when I break there is this short loud noise at every full rotation of the wheel coming from the back left i think....can't tell, it's so loud and rough and difficult to come to a full stop. The harder I step on the breaks the louder the repetitive noise. (The pads and rotors have been changed in the front last year. The back right break caliper is stuck and the rotor has rusty spots...i guess it doesn't break at all).
And lately when i turn left or right at low speeds I can hear a rubbing noise from the front as if tires are rubbing against something when I turn the steering wheel all the way.
Also the steering wheel is more loose than a few months ago.
Question: are these problems all related? Where should I start and what should i fix to make the ride smooth and healthy for the car?
Hi, I just bought a 1996 850 GLt 150k miles and love the car but i have never ridden in a car with a rougher ride!! Io it and recommendations?? int second your comments. Did you replace anything and get a better ride? How much did you put in it?? Thanks Don in Dallas
I would suspect from your symptoms that your front suspension needs a complete overhaul (struts, control arms, tie rods, etc.) and possibly the rear suspension needs work too. Apparently you're aware the "brakes" need work too.
Are you working on the car yourself or looking to have it done?
