Sponsored by:
Sponsored by: DashLynx
What is STC?
Old 07-25-2009, 02:55 PM
Booshanky's Avatar
Default What is STC?
Hi guys,
I'm sure this is a question a lot of people ask, but when I did a search it said that STC was too short of a search term.
What is it? What happens when I turn it on or off?
-Mark
Old 07-25-2009, 10:04 PM
JP's Avatar
JP
JP is offline
It's the car's traction control system. I believe it stands for Stability Traction Control. When on, it keeps the wheels from spinning by retarding some of the engine power when slip is detected. Also helps if the car starts to slide.
Old 07-27-2009, 09:45 AM
jks2's Avatar
JP is right. If it detects slippage from one wheel it will transfer power to other wheel.
Old 07-27-2009, 06:24 PM
nicolaselias's Avatar
I dont think it actively transfers to the other wheel... that sounds more like awd to me.. I think it just retards the timing to keep the revs at an acceptable level to prevent slip...
DTSC on the other hand also involves the cars braking system i believe
Old 07-28-2009, 07:39 AM
adub96's Avatar
Exactly.
Old 02-03-2016, 03:39 PM
RjsS60's Avatar
Originally Posted by adub96
Exactly.
so what does the W button do then?
Old 02-03-2016, 07:14 PM
pkrface's Avatar
"W" is for winter mode. Basically you start in 2nd gear instead of 1st the lower the torque delivery to wheels and help avoid spinning. Use only on snow or ice.
JCVolvoS80
05-01-2017 01:48 PM
njvvgirl
04-13-2008 07:29 PM
jjwjr
03-07-2008 06:05 PM
HelgaTheS80
12-08-2006 01:28 AM
JPizano23
05-12-2005 10:04 PM
Quick Reply: What is STC?
