1997 Volve 850 GLT Automatic Transmission Problems
I just acquired a 1997 Volvo 850 GLT SW. The Automatic Transmission shifts well at normal acceleration. If you go into passing gear, the tramsission will not change in a timely manner and then it changes with a hard jerk. It appears to be holding back when to the floor starting out or hitting passing gear. May not be a Transmission problem. Any ideas? Thanks, Ron
In addition to Groton's suggestion, the normal colour of the fluid for the AW50-42LE should be clear red and must not have burnt smell to it. I would flush the system with the correct fluid (Dexron-III/Mercon) and retrieve fault codes from the TCM (Trans. Control Module); your 850 requires code reader that can access TCM.
Tech, what else could it be?
JPN
JPN
Not a Transmission problem, But:
Fluid is nice. I had not driven this car, but very briefly when I posted. Trans is fine. What I think I have is the engine holding back(No CutbacK) under pressure. What does that leave? Turbo, Catalytic Converter, strarving for fuel? The engine feels like it basically slows at 55 Miles an hour & you hit passing gear. Any ideas? I drive Jaguars, not these, but thought I could use a SW. Just tell me where to start. Two scanners showed nothing, but suspect may need one with Volvo software, but I'm not taking it to the Dealer. Thanks for any help. Ron
