Water Temp. Sensor
Water Temp. Sensor
So I guess now that my brakes are fixed I'm looking at replacing the water temperature sensor. Before I do anything 1)Where is it? There is a big hose going from the radiator to the engine, and a small wire and what looks like a sensor below it, is that it?
and 2) Do i have to drain the coolant to get at this thing?
On a non turbo car...it's on the coolant overflow tank. Pull the tank up from it's holder and you'll see it on the bottom. I imagine you'll lose some fluid that's in the overflow tank, but not much.
Ken
Are you looking for the coolant level sensor or the actual coolant temperature sensor?
For the non-turbo:
The level sensor is under the reservoir.
The temperature sensor is where you said it was. Under the large hose on the engine. That's also where the thermostat is located.
I imagine it's the same for the turbo motor.
For the non-turbo:
cisopen
09-20-2010 05:25 PM
