94 850 trans problem
Old 01-28-2010, 09:21 AM
UttOOh94's Avatar
Default 94 850 trans problem
I have a 94 850. When the car is cold, the transmission stays stuck in first gear until the car is driven a few miles. I can drive with the shifter in 3rd gear and the car will shift out of 1st and up to 3rd. Once I have driven a few miles I can put the shifter in Drive and the car shifts through the gears perfectly. I have been searching for a solution online for this problem for about a month. There are many similar problems but not the exact same as mine. I am thinking about changing the transmission fluid, I don't think it will hurt, but I don't know if it will help. I am wondering if it could be a sensor or something. Has anyone had a problem like this, and have they fixed it?
Old 01-29-2010, 09:32 AM
Psaboic's Avatar
I would recommend changing the fluid, but I would definitely check the fluid level right away. It sounds almost like you are low on fluid!
Old 01-29-2010, 11:07 AM
Legendsecko87's Avatar
PNP switch will solve this problem easy
nortons
02-22-2015 11:14 PM
VolPat
06-15-2012 08:06 PM
ded137t5r
06-10-2012 07:40 PM
Eric's Hot Rod Shop
07-14-2011 08:26 AM
VTBricked
11-21-2009 07:50 AM
Quick Reply: 94 850 trans problem
