Changing spark plugs
Old 03-10-2010, 02:31 PM
nertil1's Avatar
Default Changing spark plugs
I need to change the plugs on a 2000 S80 non-turbo. Does anyone have a guide, preferably with pictures, on how to do this?
Old 03-10-2010, 05:34 PM
andrei3333's Avatar
it should be pretty easy on your car, no turbo hoses blocking anything
get a ser of torx bits or socket based drivers, take the plastic cover off, take the coils off, and there they are, its one of the easiest plug changes you can do ... lucky you
Old 03-11-2010, 09:48 PM
PieceKeeper's Avatar
To put the new plugs in, I found it helpful to use a piece of hose or tubing -- insert the top end of the plug into the hose and use it to guide the plug into the hole and start the threads.
________
Drug Testing
Old 03-12-2010, 05:59 PM
mustang's Avatar
yep, it's easy, but caution on the plug types. I tried expensive platinum--car ran worse. you should use Volvo (4-electrode type) if I remember.
Hope this helps
Old 03-12-2010, 07:30 PM
beefheart's Avatar
get the set the dealer has, six plugs in a volvo pack, was not pricy at all and my 2000 s-80 runs great, I was able to talk to two techs at the dealer and they both told me to by the original plugs, hope this helps.
Old 03-12-2010, 07:38 PM
75ohm's Avatar
Check the gaps and hand tighten to ensure no stripping.
Once I pulled the coil packs I used a small shop vac to suck all the sand and crap away from plug before removal.
Old 03-12-2010, 07:40 PM
75ohm's Avatar
I also used anti seize compound... I can tell you that waking up the plugs and getting them out was a bit unnerving.
Old 03-12-2010, 10:23 PM
andrei3333's Avatar
please dont waste money on 4+ tipped plugs ? its been proven that they dont work as advertised, remember , electricity takes the path of least resistance, and thus the current takes ONE path, not all four simultaniusly...
NGK makes the best plugs, i use iridiums, which are not cheap, but good for the long haul,,, you can just use platinums, but if you have a turbo i would not use copper...
aggriffin3
2001-2013 model year XC70
08-23-2014 10:00 AM
mustang
01-11-2012 06:22 PM
volvoQ's
04-23-2011 10:00 PM
futbolfan15
04-02-2010 09:56 PM
Quick Reply: Changing spark plugs
