Trunk won't open
Old 01-18-2006, 07:29 PM
sagi122's Avatar
Default Trunk won't open
Hi,
My trunk will not open. It was working fine a few weeks back. Nothing happens when I push the button in. I pulled the back seats down and tried to see if something was stuck, but everything looks fine. Is there a trunk release button? The manual isn't helping much. Thanks in advance!
Old 01-18-2006, 07:49 PM
Default RE: Trunk won't open
Did you try any buttons inside the car if there is any. I have a trunk release lever on my drivers door.
Old 01-18-2006, 08:22 PM
sagi122's Avatar
No...no trunk buttons in the car. I wish I had one. It would make it more convenient.
Old 01-18-2006, 08:40 PM
Hi sagi122,
Have you tried unlocking the trunk with the key? My trunk has seemed "stuck" several times, then I realized that someone locked it with the key. Sometimes, it seems hard to get it "unjammed" with the key... because it takes a few seconds to unlock it. It's worth a try...
Old 01-18-2006, 08:48 PM
sagi122's Avatar
I tried using the key, but had no success.
It's driving me crazy! I'm afraid I'll get a flat, and no way to access my spare.
I'm going back out and I'll try doing the key again. Maybe if I jiggle the key it will help..thanks!
Old 01-18-2006, 09:06 PM
I think you have to push the button in at the same time... I can't remember. It is harder than it should be though! [sm=dontgetit.gif]
Old 01-18-2006, 09:11 PM
There is a week spot in the button setup that breaks.
You will have to pull the panel from inside then open the trunk. You can fold the seats down then go in from there.
I have seen it many times. You will have to replace the button assembly.
Old 01-19-2006, 11:16 PM
sagi122's Avatar
Thanks Tech,
Looks like I will be crawling into my trunk this weekend!
Can you only buy the button assembly at the dealership.
Old 01-20-2006, 09:06 PM
Last time I knew you could buy just the button assembly.
Old 02-10-2006, 03:02 PM
I had the same problem in my '02 S40 twice. I had to open the popping screws in the trunk and tinker with the set-up of the trunk button. Something just had to been clicked back into place. What a pain :-p But the problem was fixed!
Old 02-15-2006, 05:23 PM
My 2002 s40 has a t-handle inside the trunk that you can pull from the inside and release the trunk. It is designed for someone who gets locked in the trunk so they can get out. Does your car have one?BJ
Old 02-16-2006, 09:26 AM
gordon368's Avatar
dont get lost in your trunk!lol
kasey0505
08-18-2015 03:32 PM
Vincef
03-18-2009 08:42 PM
midtown44
11-26-2005 09:45 AM
nedflack
12-16-2004 03:09 PM
Quick Reply: Trunk won't open
