Sponsored by:
Sponsored by: DashLynx
2004 s60r help!!
Old 05-31-2010, 05:54 PM
rotho's Avatar
Default 2004 s60r help!!
i just got a 2004 s60r i have a obd2 code (po299)-p and it idles a little rough sometimes and then some times it runs fine? but in between shifts it back fires(6 speed) at wot it acts like its running out of gas and popping out the exaust help please all you s60r awd 6 speed people!
Old 05-31-2010, 11:34 PM
Mad Matt's Avatar
Isn't that a low boost code? Might want to check your vacuum lines. Otherwise IIRC, it could be your TCV or boost pressure sensor going bad...
Old 06-01-2010, 11:13 AM
SVTfocusO3's Avatar
P0299
ECM-6806
Turbocharger (TC) control valve, flow fault
Pressure too low
Old 06-01-2010, 09:40 PM
Mad Matt's Avatar
iPd FTW!
http://www.ipdusa.com/version.asp?st...403&V_ID=10726
Got one on my S60R and I couldn't be happier.
Old 06-09-2010, 09:13 PM
mushroomxiii's Avatar
yeah all S60 R 6 speeds backfire a little when shifting. Mine does it too.
Old 06-09-2010, 10:09 PM
rotho's Avatar
Default s60r backfire is it normal?
2004 s60r awd 6 speed- engine miss& back fire in between shifts? no codes checked all vacume lines and put a new tbcv on still backfires and at full throtle it bogs down like its running out of gas ( brand new fuel pump was put in last week) and still no CODES !!! wtf (help) maybe a coil pack? anyway to check coils?
Old 06-10-2010, 01:12 AM
Mad Matt's Avatar
Does the bogging down feel like a misfire? What kind of plugs are you running? OEM plugs are the only plugs that always work consistently. Aftermarket plugs sometimes work great and sometimes they don't. Ask me how I know....
Old 06-10-2010, 05:48 AM
rotho's Avatar
the bogging down dose fill like a misfire! i put my oem volvo plugs back in last night. and still have a misfire maybe a coil pack prob.
Old 06-21-2010, 09:31 PM
rotho's Avatar
Default s60r backfire !
hi i have 2004 s60r i get backfire and surge no cel i just un pluged maf it runs like a batt out of hell!! can i run it this way untill i get a new maf? oh ya still no cel
Old 06-21-2010, 09:35 PM
rotho's Avatar
Default unpluged maf
can i run my s60r with maf unpluged it run great i will buy a new one this weekend will it hurt my car(unpluged maf?
Never-Enough
02-28-2011 09:49 PM
CM2RAS
10-18-2008 09:01 AM
92volvo960
01-20-2007 04:13 AM
VinUnleaded
11-17-2005 03:17 AM
Quick Reply: 2004 s60r help!!
