Removing intake manifold from '96 960 wagon
Old 07-06-2010, 08:18 AM
coleman's Avatar
Default Removing intake manifold from '96 960 wagon
I have a 1996 960 wagon that I am removing the intake manifold (installing a new gasket and cleaning up the crankcase ventilation system mess). I got everything loose and tied back, and surely enough the rubber bushing on the bottom of the manifold. It is not easy to see, and in Volvo style there is probably only one secret way to remove it easily...
Could someone please post a photo of the manifold as removed from the car, and the fastener sizes and locations for these? I am trying to find a service manual, VolvoTechInfo.com wants $315 for the entire legacy lot of TP51935 "Classic Service Information". I'm not even sure it's the right documents, but wow...
Hopefully I can get this car back on the road soon. Thanks.
Old 07-06-2010, 09:12 AM
dan550i's Avatar
There is a single nut at the bottom of the bulbous portion of the intake, it is a 13-14 size wrench, and you do not have to remove the nut, just loosen it, the bolt fits into a slot that the nut tightens down on. So removal is not needed.
It's lucky that it does not need to be removed, because it is a bear to reach, you can try to get it from the underside, but I usually kneel on top of the engine and reach down, one's hand and arm are still a tight fit from either direction.
If you choose to kneel on the engine, be sure to remove the plastic cover on the head first.
DanR '94 964 353,000 miles (119,000 miles on the new engine)
wavewright
03-22-2020 02:10 PM
Jono
10-24-2013 09:57 PM
phlosten
05-29-2010 12:02 AM
pow
04-26-2010 08:05 AM
wavewright
04-23-2005 12:57 PM
Quick Reply: Removing intake manifold from '96 960 wagon
