ETM or Breather Box? 2001 Volvo S80
Old 09-23-2010, 01:53 PM
chrisindc's Avatar
Default ETM or Breather Box? 2001 Volvo S80
Forgive me as I've seen a similar post on this topic on the forum, but my question is slightly different. My car has been surging in a "cycling" way at idle. it's 2001 with about 115,000 miles.
My private mechanic tells me that this is 99% likely to be a failing ETM, which is covered under extended warranty.
Took to dealer who said ETM passes code check and anyway it's 98% likely due to clogged PCV breather box (because "I didn't change my oil frequently enough": bogus!).
While I believe the breather box work may need to be done, my question is this: is the surging, "cycling" idle consistent with a clogged breather box?
Thanks in advance for your response and for this wonderful forum
Old 09-26-2010, 12:54 AM
mustang's Avatar
I'd try cleaning your ETM first.
here's how....
http://www.youtube.com/watch?v=8Zaxtm-hdyo
sgautam
11-27-2013 09:35 PM
Peter Reynolds1923
09-12-2013 11:34 AM
go2sharks
04-16-2011 03:04 AM
chorcheho
06-13-2010 11:02 PM
buckstom
03-16-2010 09:38 PM
Quick Reply: ETM or Breather Box? 2001 Volvo S80
