P0412 Secondary Air Injection: Valve A failure.
Old 09-28-2010, 12:23 AM
I8ASaleen's Avatar
Default P0412 Secondary Air Injection: Valve A failure.
Hey guys I've just finished some maintenance and had this code spring up when I started the car. I was messing around with the air filter and the piping for the AIR so I was just wondering where this valve was and what would cause the failure.
Old 09-28-2010, 09:50 PM
Probably a vacuum hose cracked, torn, loose.
Old 10-01-2010, 10:21 AM
I8ASaleen's Avatar
Hmm...I was messing with some hoses when I was doing the A/C. Is this Valve A the valve on the passenger side AIR? Trying to track which hoses I should check and the Chilton's Manual is none too helpful.
Old 10-04-2010, 11:53 PM
I8ASaleen's Avatar
I believe I actually mislabeled this one. It is a circuit malfunction for the Valve A on the AIR. Did something get unplugged?
I8ASaleen
07-12-2017 10:48 AM
Air Defender
07-21-2011 12:23 AM
Rakam
05-27-2011 09:03 PM
bigdummy
08-01-2009 03:18 PM
jrw
11-19-2005 09:13 PM
Quick Reply: P0412 Secondary Air Injection: Valve A failure.
