Climate control removal
Old 03-24-2006, 12:38 PM
RocknTommy's Avatar
Default Climate control removal
Blower motor not working. Bench tested and its fine. Everything I can track down seems to be in the Climate Control. Any tips on removal?
Old 03-24-2006, 09:22 PM
Default RE: Climate control removal
Do you have ECC or MCC
ECC= Electronic climate control
MCC= Manual climate control.
If it is a manual. Then pop off the trim molding. Then you will see 4 screws holding it in remove the screws.
Then you will see 2 metal tabs folded over it. Bent then straight and it should slide out.
Old 03-27-2006, 12:25 PM
RocknTommy's Avatar
This one:
pic
Old 03-27-2006, 09:12 PM
You got it. I think the blower switch is seperate and can be replaced.
Old 04-05-2006, 05:12 PM
RocknTommy's Avatar
Default RE: Climate control ISSUES
Climate Control not working.
Lights up but thats about it.
Bench tested the fan motor and it is fine.
Fuses check fine.
Swamped in another climate control unit and still no function.
Cant adjust the thermostat, no fan.
Seems like it is not getting power?
Suggestions?
Thanks!
Old 04-08-2006, 02:59 PM
Make sure the back of the fuse panel isn't melted and not making a connection.
bestharry
02-08-2023 08:21 AM
Bud SD
01-12-2010 11:25 AM
jfikentscher
05-31-2006 09:58 PM
tomservo
03-23-2005 10:28 AM
watson6033
02-24-2005 12:08 AM
Quick Reply: Climate control removal
