Sponsored by:
Sponsored by:
Check Stop Lamp
Old 03-25-2011, 12:18 PM
ankitjuthani's Avatar
Default Check Stop Lamp
I just bought a used 2003 XC90 T6. I have a small problem that just started two days ago... When i step on the breaks, I get a message "Check Stop Lamp" I've read some forums and it says to replace the break relays. Is that correct? is there a way to find out if thats the issue or something else. Please help.
Old 03-27-2011, 12:18 PM
ed7's Avatar
ed7
ed7 is offline
First, check for a bad bulb.
Ed
Old 03-27-2011, 12:42 PM
stonepa's Avatar
Bad bulb or a loose bulb. Volvos (at least all of mine) seem to have this loose bulb issue more often than not.
Old 03-28-2011, 08:27 AM
04XC90T6AWD's Avatar
you probably have a burned out tail-light could be the left could be the right or the high mount it could be 1 of them 2 of them or it could be all 3 before you go replacing brake relays check your stop lamp. Word of caution when going to fourms/ garages for help. No matter what they tell you start with the solution that costs the LEAST! amount of money then work your way up.
Old 01-05-2012, 05:27 PM
sdawson's Avatar
Its the bulb! 100%
spikedmd87
07-14-2021 04:25 AM
murphysmotors
01-21-2021 06:52 PM
sas80
08-11-2011 08:57 AM
ankitjuthani
03-25-2011 12:28 PM
vwbusman
10-28-2009 08:12 PM
Quick Reply: Check Stop Lamp
