2005 S40 Sunroof Drains
Old 04-16-2011, 07:31 AM
hermsen's Avatar
Default 2005 S40 Sunroof Drains
I'm getting water in the rear passenger-side footwell of my '05 S40 (non turbo) after a rain. I've cleaned the front sunroof drains, but can't see the rear ones. Does anyone have a diagram showing their locations? Since the water is collecting in the rear, I suspect that I need to get the rear drains cleared.
Thanks.
Old 04-16-2011, 07:37 AM
First thing I would do is pull the A-pillar trim and make sure the hoses are attached. They are well known to pop out of the rubber elbow by the firewall.
Old 04-16-2011, 07:43 AM
hermsen's Avatar
I've already checked the front drains. They're connected and drain nicely (after a little coercion from an air compressor). I can't see the rear ports though. Any idea how to access them?
Thanks...
Old 04-16-2011, 08:07 AM
hermsen's Avatar
OK. Finally got a chance to take the trunk liner out. Followed the tubes from the sunroof and found the drain ports just in front of the bumper, about a foot in from each side. Hooked up an air gun to my compressor and blew out the lines. Now, they drain great. I (slowly) poured about a gallon of water into the sunroof tracks. Drainage was good. Hope this can help others who have the same problem.
JerrySC
2001-2013 model year XC70
12-12-2012 01:02 PM
austeve
05-07-2009 11:12 AM
s80Bluez
06-28-2007 04:56 PM
spinningcain
08-20-2006 02:52 AM
jcmartin
08-22-2005 01:49 PM
Quick Reply: 2005 S40 Sunroof Drains
