leak in vacuum
leak in vacuum
I just bought a 2004 s60 with 140k miles. Occasionally when driving slow or coming to a stop it will stall. I had autozone pull the codes and it could have an engine vacuum leak. What is the best way to locate and fix? Are there common areas I should check? Where should I start?
I have replaced the air filter and the small hoses are all connected,
