OD Solenoid bolts
Old 06-20-2011, 04:41 PM
beerbobj's Avatar
Default OD Solenoid bolts
Hey guys, my overdrive occasionally shorts out and so I was going to install an IPD bypass plate, but I can't get the bolts for the solenoid loose. I've tried a couple times, even getting a stubby 12 mm flex wrench and no go. Any suggestions? I hate to take it to the mechanic for something so simple, but I'm running out of ideas. Thanks.
Old 06-20-2011, 04:56 PM
avguy's Avatar
Are you using penetrating oil?
Old 06-20-2011, 06:10 PM
beerbobj's Avatar
I haven't yet. I've tried spraying WD40 on it a couple times because that's all I had on hand. What do you suggest? I've never used penetrating oil before.
Old 06-21-2011, 12:06 AM
avguy's Avatar
Old 06-21-2011, 07:36 AM
beerbobj's Avatar
Thanks. I'll pick some up on my way home from work tonight and give it a shot.
Old 06-21-2011, 03:58 PM
MNWILD's Avatar
beerbobj, make sure it's not a bad connection where your relay plugs into the spade connectors. I thought i needed a new solenoid & it was just a bad connection.
Old 06-22-2011, 03:28 AM
if you can't find Blaster PB, look for Kroil.
WD40 has its place, but its not a penetrant, its a moisture repellant, basically kerosene and light oil.
adamtessin
02-28-2007 09:19 PM
thullz
10-31-2006 02:14 PM
Reilly_S70GLT
09-05-2006 08:57 PM
westcoast gt
07-31-2005 10:56 AM
Quick Reply: OD Solenoid bolts
