A/C compressor works but no cold air ?
Old 07-21-2011, 08:31 AM
pdieni's Avatar
Default A/C compressor works but no cold air ?
My A/C was working for a while but its really warm now. The compressor turns on and off but I do not get anything for cold air. When it was working if i gave the car gas it would get warm and the air flow would shut down too ? Any ideas ?
Old 07-21-2011, 09:36 AM
lev's Avatar
lev
lev is offline
Sounds like the system is low on refrigerant. And you need the valve that controls the vacuum to the vents, the exact name escapes me but a Volvo place knows what it is-cost little and is easy to fix.
Old 07-21-2011, 12:51 PM
pdieni's Avatar
Where is this valve ? Passenger area or in engine bay ?
Old 07-21-2011, 04:00 PM
gabyman97596's Avatar
Check freon levels first. and the valve is located with te car on front to ur left near the dryer I think is called is has switched on it.
Old 07-21-2011, 09:56 PM
Henry10's Avatar
In addition to what Bluewater1 did here, in your case, I would also replace the Heater Control Valve (which is in the engine compartment, on one of the heater hoses/lines). These valves are cheap: $ 15-18 shipped.
When you check the Vacuum Controller, check the vacuum lines for cracks. Check also the vacuum reservoir for cracks.
Old 07-22-2011, 08:38 AM
swiftjustice44's Avatar
I'm guessing you have automatic climate control? ACC? If so, there is also a very good chance the controller is weak or bad. On my 760, I could not use the auto position. I had to put it about 85 degrees and when the temp got down to that, I would start easing it down a few degerees at a time. Eventually it would cool at the temp I wanted. Air flow diminishing is a vac issue. It's quite possible you have a number of issues going on simultaneously.
blackbrick
2001-2013 model year V70
08-14-2014 07:11 PM
gianni
2001-2013 model year XC70
09-18-2013 03:33 PM
bb1
18
09-03-2013 01:32 PM
S802001
03-29-2010 08:54 AM
floryed
01-26-2008 07:06 PM
Quick Reply: A/C compressor works but no cold air ?
