940 transmission problems
Old 10-18-2011, 11:10 AM
Jakeness's Avatar
Unhappy 940 transmission problems
I have a 1995 940 turbo wagon, 4-speed automatic. Recently the 4th gear has randomly been disengaging itself, and the car has essentially become a 3-speed. I tried pushing the button on the shift **** but it won't re-engage. Has anyone else had this problem?
Old 10-18-2011, 12:53 PM
brickrunner's Avatar
How many miles does the car have and when was the last time that the transmission fluid was changed? The first thing that I would do is check the color and level of the transmission fluid. The button on the shifter is overdrive so that isn't going to take care of the problem, in fact it will prevent the car from going into fourth.
Old 10-18-2011, 06:52 PM
jagtoes's Avatar
Check your overdrive relay if it is intermittent or dead it will not get out of 3rd gear. Also take bricks advice and check/change the fluid.
Old 10-18-2011, 09:18 PM
Jakeness's Avatar
Thanks for the replies. The car has just over 99K miles on it, but I'm not sure of when the last time the transmission fluid was changed. I'll check it first thing in the morning.
I'm beginning to think it may be an electrical problem and not a trans problem, because it will randomly go on and off for reasons I can't figure out.
Actually, the button is how you select if you want fourth gear or not. It is essentially overdrive, though. When you press it, a light goes on the dash showing that it will not go into fourth. The same button can be pressed to re-engage fourth, so it was my first instinct when the light went on for no reason. It doesn't work, however.
Old 10-18-2011, 09:36 PM
It's probably your overdrive relay.
jeffrisley
06-14-2015 01:48 PM
flgal
08-28-2012 08:05 PM
cosmo
11-24-2009 04:37 AM
ogotaj
03-22-2008 02:57 AM
volvo13
10-09-2003 01:36 AM
Quick Reply: 940 transmission problems
