940 Parts Interchange??
Old 10-31-2011, 07:27 PM
legendarydave's Avatar
Default 940 Parts Interchange??
Hey folks,
My volvo cherry is still being broken, so, be gentle with me.
I picked up this 1994 940 over the summer. Great deal, needed an engine, no problem. So far, everything has been super easy. I haven't run into any mechanical walls that I couldn't overcome.
The ease and simplicity are making me think, this car isn't going anywhere for a while. It's like my Fox Mustang and Old Tracer got together and the offspring inherited only the best traits. I missed those cars, until this 940. I want this car to look good, for the long haul. I already know it really moves, so I'm not too concerned with power.
Now, what I really want......
I need to know everything that interchanges from other volvo models. I am sure that many of you have found different parts that can swap between them.
I am most interested in cosmetic stuff. Engine internals are simple, drivetrain isn't too tough to work with either. The only qualm that have is the short supply of more stylish body accessories. I have noticed that the 850 looks quite similar to the 940 and that 850R front bumper would look **** on my 9... Anyone think it will fit?
OK, not just cosmetic, how about brakes?
Interior?
Turbo stuff?
etc etc.....everything and anything
Anything you can offer would be great!!!! There are no bad ideas!!!
cheers
Last edited by legendarydave; 10-31-2011 at 07:31 PM. Reason: additions to explanation
Old 10-31-2011, 07:39 PM
brickrunner's Avatar
No, the majority of the parts aren't interchangeable. The 940 and 850 look similar but they are very different. The 940 has a 4 cyl. engine and it's RWD. The 850 has a 5 cyl. engine and it's FWD.
Old 10-31-2011, 09:32 PM
lev's Avatar
lev
lev is offline
940 will interchange with 960, s90, v90 (Wagon), and 740. That's it. Pretty much nothing from a FWD platform.
Old 11-01-2011, 12:43 AM
and 740/940/760/960 that have the integral fog lamps have a different grill, and different hood than the ones without integral fog lights. further, the integral fog lights, some of the cars have an aluminum hood that half covers the wipers, without the normal cowl vents, while others have the standard cowl. so thats 3 different hoods.
the 740 sedans had way different rear windows and trunks, flat/square, while the 940 sedans gained a deeper trunk, and more sloped rear window. the wagons, OTOH, were almost unchanged, except the usual year by year minor mechanical changes.
740's from 1991 and 92 are just about identical to the same year 940s. except the 940SE is really a 960. the 760/940se/960 have significantly different electrics and dashboard innards. of course, the regular 760 was a V6 (but the turbo 760 had the same engine as the 740/940 turbo). and the 960 is an inline 6.
the last year 960s (1996?) and the S/V90s from 97/98 have significantly modified exterior trimmings, different bumpers, skirts, side trim, window molding treatment, etc. they also use different offset wheels. Those last version wagons gained the IRS system similar to that previously used in the 960 sedans, too.
Old 01-31-2017, 12:02 PM
Steve Walters's Avatar
I'm having trouble finding body part replacements for my 94 940 turbo brick. Looking for a quarter panel, a door and a tail light. Will a 1990 740 work for those parts? Thanks in advance for any info.
Old 01-31-2017, 02:36 PM
1990 was a transition year. 1991+ should be mostly interchangable, but 940 has some cosmetic differences over 740. 740 sedan rear ends are /totally/ different than 940 rear ends.
1990ish 740:
940 rear end:
Old 02-01-2017, 06:05 AM
Thanks, pierce!
Old 10-11-2022, 07:25 PM
lesismore's Avatar
Wondering in terms of interior parts if a 1995 940 would have interchangeable parts with a 1997 740. Specifically a seat motor for the driver’s seat - and/or the seat itself, if it has a manual adjustment lever.
Old 10-12-2022, 02:49 PM
admasters's Avatar
The seat motors should be swappable, the drive cable is the failure point usually. However a manually operated seat will fit into a car that had electric seats, with the advantage that you actually sit a little lower in the vehicle.
Old 10-12-2022, 03:13 PM
lesismore's Avatar
Thanks! I’m not actually sure if it’s the cable or other components that have failed, I need to ask the mechanic that took it apart. Thank you
Old 10-13-2022, 07:55 AM
lev's Avatar
lev
lev is offline
Originally Posted by lesismore
Wondering in terms of interior parts if a 1995 940 would have interchangeable parts with a 1997 640. Specifically a seat motor for the driver’s seat - and/or the seat itself, if it has a manual adjustment lever.
What's a 640?
Old 10-13-2022, 08:08 AM
lesismore's Avatar
Sorry that was a typo! Thanks for catching it. 640 = 740. Editing my post now 😎
KyDave
03-14-2020 10:02 AM
mphilleo
03-09-2016 07:52 AM
mphilleo
01-22-2016 10:27 AM
mosh
11-03-2013 04:11 AM
Buck
08-05-2005 09:36 PM
Quick Reply: 940 Parts Interchange??
