Sponsored by:
Sponsored by: DashLynx
2004 S60 Fuel Pressure Problems...Help!
Old 12-05-2011, 09:07 AM
the tenor man's Avatar
Default 2004 S60 Fuel Pressure Problems...Help!
Hello,
I'm new to the Volvo S60. This one has about 95,000 miles on it.
The dealer has just replaced the Fuel Pressure Sensor under recall. The problem was surging and stalling. The new Sensor didn't solve the problem.
I connected my code scanner and the fuel pressure is jumping all over the map. It goes as low as 5lbs. when driving (car jerks) and as high as 78lbs. and also throws a fuel pressure sensor code.
The mystery is that after about 30 minutes of driving, the car settles down and runs fine. The fuel pressure stays at about 54-55 lbs. I've erased the code and it doesn't return until the next day when the engine is cold when the problem starts all over again.
Could this be a loose wire on the fuel pump, a bad fuel pump or a bad fuel pressure sensor?
Any help would be greatly appreciated...many thanks in advance.
The Tenor Man
Old 12-05-2011, 09:20 PM
hotrodln's Avatar
how about a bad fuel pressure regulator? stay stuck open in the morning ( low press) or stuck closed ( high pressure) later?? I'm new to volvo's but i've had similar issues with other cars.....if these cars are like other ones i've worked on, the fuel pump always runs.....constant flow rate......the pressure regulator adjusts the pressure by allowing some fuel to flow back to the tank......worth thinking about!
MntnDewMan
04-03-2024 04:05 PM
jmpaul88
08-14-2014 08:39 PM
Huck
01-07-2014 08:46 AM
hoffmandirt
01-24-2010 06:25 PM
chaniewski
11-13-2007 05:50 PM
Quick Reply: 2004 S60 Fuel Pressure Problems...Help!
