1999 volvo v70 xc
Old 12-11-2011, 01:35 AM
jiml100's Avatar
Default 1999 volvo v70 xc
Anyone know how to check a cv axle, front drivers side, was told it is bad. Vibration at freeway speeds, now i also have a vibration at normal speeds like 20 or 25 mph, if i put it in nutreul and coast it still has the vibration. , boot is torn and gone. Anyway for me to be sure before i tear it all apart ? Thanks for any help.
Old 12-12-2011, 08:44 PM
Man, sorry no one has helped you with this. I wish someone would do a good suspension write up for others to DIY. I don't know myself.
Old 12-12-2011, 11:02 PM
Matt Lagusis's Avatar
try moving the front tire to the rear and drive it to see if the vibration moves to the rear.
To check CV...turn left from a stop and liten for the click, click, click. Try it again turning right too.
Old 12-13-2011, 07:48 AM
MSGTUSMC's Avatar
Torn rubber boots allow contamination of these units which causes pre-mature abrasive wear. Replacement is the only safe repair. Faulty CV units can cause dangerous vehicle operation! Costly front end suspension work! Inspection by good front end alignment shop important.
rezology
06-13-2010 10:42 PM
MarkInTexas
06-11-2009 12:16 AM
cncinc
05-31-2009 04:25 PM
7antera
06-02-2008 08:00 AM
haroldh13
12-14-2006 10:33 PM
Quick Reply: 1999 volvo v70 xc
