Sponsored by:
Sponsored by: DashLynx
Fuel Pressure Problems
Old 03-17-2012, 03:22 PM
odbii's Avatar
Default Fuel Pressure Problems
Have an 07 S60 2.5T 2WD and it's have an issue with long crank times to start. I checked the battery and that is fine so I put a fuel pressure tester on it and came up with theses values.
43 PSI @ Idle
40-43 PSI @ Acceleration
50 PSI @ During Turbo Boost
30 PSI @ Off
54 PSI @ Start - Then down to 43 PSI during acceleration
Been doing long crank times for the last 2 years was told by dealer it's normal. Now it stumbles when starting and the crank times are about 5 seconds now.
Any thoughts, maybe fuel pressure regulator?
Searched and found nothing really.
MntnDewMan
04-03-2024 04:05 PM
the tenor man
12-05-2011 09:20 PM
slsnumber1
03-15-2011 02:55 PM
skyrider20
11-29-2008 07:01 PM
chaniewski
11-13-2007 05:50 PM
Quick Reply: Fuel Pressure Problems
