Replace Key Fob Battery?
Old 04-29-2012, 10:13 PM
mcgiiver's Avatar
Default Replace Key Fob Battery?
Does anyone know how to open the key fob to replace the battery?
Old 05-24-2012, 04:03 PM
PieceKeeper's Avatar
?? What year?
The FOB with my 01's have a torqx screw, back it out, pry open the FOB.
Old 10-26-2018, 10:11 AM
newcider's Avatar
same question on 2015 key fob
no obvious seams to pry apart !
aha!
Used emergency key to pry (lightly) inside fob's key slot enough to crack open the lid, then use a thin but not sharp metal blade to separate lid from fob (think butter knife).
Battery falls out.
However, after new battery was installed i'm getting "key not found" too often unless I put fob in receptacle in dash.
Old 06-28-2021, 08:10 AM
mgroth's Avatar
I took apart the org key where proximity works and the new one where it doesn't and see they are not same. The one where it works has part number that ends with *66 and has 2 batteries, the new one has part number that ends with *64 and only one battery. so my conclusion is I probably bought the wrong key
LisaMac8530
09-04-2013 06:25 PM
LisaMac8530
09-04-2013 12:44 PM
jparnes1
2001-2013 model year XC70
07-11-2012 02:31 PM
sktrmoss
03-11-2011 08:45 AM
joejoecat
02-09-2010 09:51 PM
Quick Reply: Replace Key Fob Battery?
