CV Boot Removal 850
RE: CV Boot Removal 850
Used WD-40 and I split a Husky socket trying to spin that bolt, so that sucker is in there!
Took your advice and removed the two strut bolts and got the drive shaft out of the hub. I'm taking a break before I try to remove the axle from the trans or pull the outer CV boot off. The CV joint is not showing any obvious signs of damage. I have the boot kit, but if that's too difficult, I may go buy the axle. It's my first time ever doing this, so the learning curve is a big one, but I'm determined. Thanks for the great advice, Scott
Which side Axle is it?
If it is the Right side (Pass. side) then you will need to remove the 2 12mm bolts holding the Axle support bearing to the engine and it will slide out no problem. If it is the Left side (Drivers side) then you will have to pry between the Axle and transmission to pop it out.
When you get the Axle out clean the Joint good. Where the Axle goes into the Joint you will see a Clip that needs to be spread. You will need to hold the clip open (spread) then Tap the outer joint off.
Sometimes they can be a Bear as well.
Driver's side. Geez that was a b**** prying that axle out. I was hoping I'd be able to get the CV joint off without removing the axle. But after discovering the ring clip opening was on the bottom side, I had to pull it out. If I could get the d*** axle today, I would replace the whole thing after all that work. But I need to get this car ready for inspection on Monday, so I guess I'm going to attempt removing the CV joint. And yeah, everything I've read says it can be really hard to remove. Wish me luck!
Scott
Scott
Good Luck.
BeCaferul hammering on the Joint. I always use a Brass Punch. If you don't have one then make sure you Tap on the outside edge carefully.
I have also seen some just fall off when you open the Clip.
Do you have like a CV pro's near you or something like that where you could bring it and have it rebuilt today?
No, I don't have a brass punch, and if there's a CV pro shop near me, I'm unaware of it. If worst comes to worst and I ruin it, I'll wait until Monday and buy the whole darn axle. I've read tips like using the right size socket as a tap. I'm going to tackle it shortly. I'll let you know how it goes. Thanks again for your time and advice.
Scott
Scott
OMG, first break of the whole job. I actually got it off in about 5 minutes with only some light tapping on the outer rim with a plastic screwdriver handle. I think I have some engine degreaser around here somewhere that I could clean it with.
Of course I'm covered in grease too. Probably just toss this old t shirt I'm wearing when I'm done.
Hi tech, thanks for Kudos!
OK, so I started cleaning this thing. the degreaser I have is the foaming type. I'm a bit concerned that it's not the right kind to use. I'm also worried about how I'm going to wipe it all off, especially on the inside. And how clean do I have to get this thing? Is there another product I have to use to remove the degreaser?
Scott
Scott
Do you have any Brake or Carb Cleaner?
If not and all else Fails Rinse with water and try to as fast as possible.
Then pack the Grease in there really good.
What alot of peopl don't know is alot of people at Dealerships wash parts with the Parts washer then rinse them with Water blow them dry with compressed air and put all back together.
Yes just clean it the Best you can then install the Grease from the Boot kit.
TIP: Only cut a corner out of the Package if it is in a square thin plastic envelope type thing. Then stick the opening in by one of the ***** and squeeze the Grease in like that. Do that all the way around then with the left over after that is all done squeeze it into the Hole in the joint.
OK, carb cleaner was the answer. Can I also use it to clean up the ball joint, tie rod, inside of tire rim, etc. ?
I received two skinny silver packs of grease. I'm pretty sure I don't have the turbo, so I suspect I only need one pack.
The VIN code....
YV1LW5647V2307626
56 = B5254T Emissions = 4 (850AWD Canada)
4 = w/o EGR w/air pump, w/OBDII, w/elec. control evap,
Is that turbo? is there anyway I can tell for sure?
TIA, Scott
The VIN code....
YV1LW5647V2307626
TIA, Scott
Yes you have a turbo engine.
The packs of grease should be the same for turbo and Non-turbo.
The reason they give you 2 is because the kit usually does both joints inner and outer.
They Grey Dark looking grease is for the outer joint. The Tan looking grease is for the inner Triepod joint.
The axle will push into the Trans. If it doesn't go right in CAREFULLY Kind of use the Axle like a Slide hammer. Pull the Axle shaft out a little then push it in hard. Make sure it snaps in all the way.
