ETS Light/Safe or Limp Mode
Old 06-24-2012, 11:14 AM
Matt Lagusis's Avatar
Default ETS Light/Safe or Limp Mode
I bought a 1999 V70 XC with the ETS light on 3 years ago with 120,000 miles. The car now has 185,000 and I have not changed the throttle body. About once a month it goes into limp mode, I then shut if off, start it up and it is fine for a month or so until it happens again. We easily put 300 miles a week on the car.
So my questions are as follows:
1) what is the worst thing that could happen with the ETS light on other than the occasional limp mode?
2) Am I pushing my luck by not changing it or should I just wait for the worst to happen?
3) Is the fix an easy one? How much should I expect to spend?
Old 07-02-2012, 11:28 PM
gdog's Avatar
Old 07-25-2012, 11:11 AM
CTChris's Avatar
Default not all questions answered
Hi - I would very much like to hear a direct answer on the original point #1 and point #2. xemodex.com does not answer those questions.
Old 07-30-2012, 01:58 PM
eMac52's Avatar
I am having the similar problem with a 01 S80. Fuse 7, Throttle Module fuse blows. It did in the exact same location two nights in a row. Change fuse and everything is fine. Yesterday it blew two fuses one in morning and one evening different locations. Today I made same round-trip and no fuse blowed. When fuse blows care will start on about third or forth try with RPM slowly increasing up to about 2700 max. Vehicle in safe mode until fuse is replaced. Checked for codes at Advance...no codes or Service engine light. I know there was a recall on Throttle Module. I am just outside the 10 year. Vehicle has 138,000 miles and no other issues in history. Has me perplexed. Am going to remove the Throttle Module and clean it and see if that works. I am told this will only mask the full replacement. Above mentioned company seems to be best place for replace module. $500 vs 1100 at Volvo. Great car till this now I am very nervous. Volvo dealers in US seem to all be thieves. Why can't they give decent service without the rip off ? I really am tired of repair shops ripping customers off for parts and service they do not need. $$%$&(_)+*_+&#$
Old 08-22-2012, 07:20 PM
just found the Sacer part that xmodex puts in to rebuild the volvo unit for $160 on ebay. Save $500 and do it your self fix...sounds good to me. I wil document the repair when I do it.
Old 08-23-2012, 12:04 AM
gdog's Avatar
"Sacer" ??
Link please...?
The following users liked this post:
Spuddy (05-20-2022)
lehrskee
07-25-2014 01:19 AM
jzmcpherson
12-24-2013 07:30 AM
Matt Lagusis
1998-2000 model year V70
06-21-2012 10:49 PM
Calvin Cheney
05-29-2012 11:13 AM
swede850T
07-04-2005 03:44 PM
Quick Reply: ETS Light/Safe or Limp Mode
