Code P0410
Old 06-29-2006, 09:23 PM
Z06john's Avatar
Default Code P0410
How do I reset this code P0410, I replaced the shut off valve and beleave I have the problem fixed. I pulled the neg. battery cable but when the car relearns or does a drive cylce the check engine light comes back. Thanks for any help.
Old 06-29-2006, 11:24 PM
Default RE: Code P0410
You will need to clear it with a scanner.
Old 09-04-2006, 10:58 PM
hordezla's Avatar
Not to open a new topic since I have the same problem, same code that is, I will continue on this one.
I see that ZO6john replaced shut off valve to get rid of the po410, is that the only part that can trigger this code? And where is it located?
thanks!
Old 09-05-2006, 08:16 PM
The shut off Valve is inline. Look for a Metal Valve at the back of the engine and Follow hose to Valve.
Old 09-06-2006, 08:08 PM
hordezla's Avatar
thanks for your help!
Is it possible that this code came up because one of the 2 little hoses (white one) on the airbox was off completely? As I was trying to look for shut off valve I've noticed that this hose was just hanging in the air, I put it back in the air box and I am hoping that this was the problem that caused p0410-> Secondary Air Injection System.
Tech, could it be?
Old 09-06-2006, 09:08 PM
Sorry but no.
Do you hear the air pump run first thing in the morning?
Old 09-07-2006, 12:55 AM
hordezla's Avatar
Well, that didnt last too long[:@]..check engine came back on after few minutes.
I am not sure about the pump, will try it in the morning.
Old 09-09-2006, 11:04 AM
hordezla's Avatar
I cant find shut off valve on any of the sites where I've looked. Does it go by some other name maybe?
Old 04-10-2008, 09:09 PM
Should the air pump run when the car is cold as soon as you turn the key on? Or do you need to start the engine? TIA.
Old 05-05-2009, 08:58 PM
V70-T5's Avatar
i just got this code today as well this is getting stupid, seems like one code after another. i had a bad catalytic converter ( main cat efficiency ) o2 sensor sensor 2 was killed because of the blown up cat, now this.
Old 05-07-2009, 04:39 PM
V70-T5's Avatar
problem solved on mine, it was a vacuum hose that was deteriorated
Fixityourselfer
01-04-2016 08:57 PM
rob960
09-07-2011 08:28 PM
92Typhoon
04-25-2008 06:59 PM
safari
12-10-2007 07:46 PM
BrianB1975
07-13-2006 01:07 AM
Quick Reply: Code P0410
