How many fault codes can you fit in one Volvo????
Old 11-06-2006, 08:26 PM
uncle's Avatar
Default How many fault codes can you fit in one Volvo????
TCM-002F Lock-up function Slipping or not engaged
TCM-0100 Control module Faulty signal
AUM-47FF Amplifier Faulty installation
AUM-41FF Amplifier, sub-antenna Signal missing
CEM-1A59 Communication with AUM control module Signal missing
CEM-6A01 Door unlocked, left rear signal too high
CEM-1A5F Communication with ABS control module Signal missing
CEM-1A62 Communication with ECM control module Signal missing
DIM-0006 Orange warning lamp Faulty circuit
DIM-FFFF No eroor code description
DDM-0049 Control module Internal Fault
Symptoms
occasional clunky gear shifts (only when hot. When it starts to do this i shift manually and she's a lot better but not perfect)
Hissing brakes
Slightly reduced performance, slow shifting, slow throttle response
Its pretty good to drive now. I'm not in a desperate hurry to fix anything. I would like to get the performance to a level that i don't regret buying an auto. I always said I never would, why i did i'm not sure. But i still love her.
2000 (2G) V70 T5 Geartronic
Old 11-08-2006, 07:06 AM
v70 2.4t's Avatar
Default RE: How many fault codes can you fit in one Volvo????
hey Uncle, any cliffs near your place......
Might be your answer..
V70 2.4t
Old 11-08-2006, 09:37 AM
uncle's Avatar
I've been trying to think of the safest way to write it off. The Harbour is looking like an attractive option.
Just kidding. Very little of what is wrong with her is obvious to me so i really enjoy driving her. And until that changes i won't be spending a fortune to fix anything. But I will be keeping a close eye on her.
Old 11-08-2006, 09:39 PM
uncle's Avatar
The dealer's main concern was the ABS module. The ABS message only comes on internittently at the moment. Even though it reads as a permanent fault.
My Transmission Service Required message hasn't returned since i had it cleared and the transmission is running beautifully since my last flush. just the very occasional and almost unnoticable knock changing down in to 2nd. I'm glad i didn't fork out the $6K for a new tranny when Volovo 1st told me i needed one.
Old 11-08-2006, 09:58 PM
Bad ABS module can throw almost all of those codes.
It will block communication when it goes bad.
Old 11-08-2006, 10:37 PM
uncle's Avatar
What is the Lock-up function that is apparently slippipng or not engaged?
Old 11-09-2006, 01:38 AM
v70 2.4t's Avatar
Uncle, If you log onto ebay Usa, there is a guy that rebuilds ABS Modules
with a life time warrenty, they are quite easy to pull out.
might be worth a look he charges $75.00US about $100.00AU+ shipping..
V70 2.4t
Old 11-09-2006, 08:45 PM
The torque converter isn't locking up. Someone on here may be able to answer better on the function of how it works.
Never really messed with the internals of the trans or torque converter.
Try having the ABS module rebuilt.
v1lcins
05-20-2022 10:53 AM
jakefitz
03-31-2009 02:38 PM
diehardgator1
09-09-2008 06:52 PM
1990TURBO740
12-25-2006 04:23 AM
Quick Reply: How many fault codes can you fit in one Volvo????
