1996 960 P0117 error code
Old 11-10-2006, 11:40 PM
jonemory's Avatar
Default 1996 960 P0117 error code
i was throwing a P0115 error code and car would not cold start unless my cars key was in the on position for around 15 minutes then it would start. now i got a new ecu that fixed the problem for a few days now my car throws the code P0117 code for a engine coolant curcuit low input.... any ideas of what that could be... when i start my car it has trouble with the throttle when i put the gas on while its cold but once it warms up it does fine.... my temperature guage also jumps around from sometype of electric spike.... any input would help,,,,
Old 11-11-2006, 02:19 PM
Default RE: 1996 960 P0117 error code
Bad coolant temp sensor or thermostat. I would replace both.
Old 11-11-2006, 03:00 PM
jonemory's Avatar
i had replaced that before when it was throwing the P0115 code and it did not change the situation... and i just put in a new thermostat a few months ago... could it still be the sensor if i have tried it before.... my code says it is a coolant circuit low input problem....
Old 11-11-2006, 03:02 PM
Check and see if you have a second coolant temp sensor in the back of the head.
Some of the cars have 2 sensors on in the thermostat housing and the other in the back of the head.
Old 11-11-2006, 03:25 PM
jonemory's Avatar
no there is only one underneath the thermostat on my car... the mechanics have thought there was a second one also... but they realized my car only has one...
Old 11-12-2006, 11:49 AM
Then maybe there is a wiring problem to the coolant temp sensor.
The P0117 is also a coolant temp sensor code signal to low
Old 12-01-2006, 04:57 PM
jonemory's Avatar
do you have any idea how i would go about checking the wires to the coolant temp sensor.... where should i start checking and where would be some likely things...
Old 12-01-2006, 08:54 PM
That is not a common problem all I can do is give you this like to get a wiring diagram to go from there.
http://www.volvotechinfo.com/WD123/
rchchmb
05-11-2008 09:57 AM
khesser
07-02-2007 11:37 AM
Anns V70
09-07-2006 11:53 PM
fast850r
10-07-2005 09:26 PM
DavidSchneider
07-07-2005 12:17 AM
Quick Reply: 1996 960 P0117 error code
