Crankcase breather filter.
Old 12-27-2006, 05:18 PM
blackstarpower's Avatar
Default Crankcase breather filter.
My xc has 140k and I am suspecting the flame trap setup is clogged.
What do you think about just adding a little crankcase breather filter to the line coming out of the crankcase, or just routing it to a catch can.
The OEM kit that ipd has is pretty expensive, so I was seeing if what I mentioned above would be an OK alternative.
Also, would the PCV valve not be in the system anymore if I added just a crankcase breather filter to the end of the tube coming out of the crankcase?[/align]
Old 12-28-2006, 10:42 AM
Default RE: Crankcase breather filter.
I don't think that will do anything.
If the system is clogged the filter will do nothing at all.
I would try to get the vent box and replace.
Old 12-28-2006, 01:46 PM
What about just routing the crankcase line next to the oil filler cap into a catch can? That is how I had my setup on my Subaru. What is the significance of all the excess lines?
Old 12-28-2006, 01:56 PM
It is for the engine to breathe internally.
If it gets clogged up to bad it will start making the seals leak.
If it is clogged in the box the engine still won't breathe even with the hose setup you want to do.
Old 12-28-2006, 02:01 PM
Crap. I need to get this done asap. Is there other lines coming out of the crankcase too besides the one next to the filler cap? Is that why it can't breath properly. There has to be some sort of alternative.
Old 12-28-2006, 02:23 PM
Size:  31.2 KBName:  Picture349.jpg
That is the system with all the lines.
Old 12-28-2006, 03:10 PM
So it looks like all I would need to do is take the two lines going into the catch can, cut them up top, and route new hoses into a new catch can.
Right?
That diagram is great btw, thanks.
Old 12-28-2006, 03:45 PM
Still not sure that will work.
The bottom of the Vent box goes to the engine as well.
Which has a port to.
Old 12-28-2006, 03:49 PM
I believe, (could be wrong) that the port on the bottom is just the nasty oil being recycled back into the engine. Anybody know if that is true.
Old 12-29-2006, 10:08 PM
I think so but not sure.
go2sharks
04-16-2011 03:04 AM
apeman
05-16-2009 07:36 AM
sporky
05-30-2008 07:10 PM
proplasm
01-31-2006 10:14 PM
Ocotillo
03-28-2005 04:02 AM
Quick Reply: Crankcase breather filter.
