1999 S 80 T6 service light can't reset
Maintenance Required Lamp/Indicator: Service and Repair Resetting Service Reminder Indicator (SRI)
Resetting the service reminder indicator (SRI)
Hint: The indicator can also be reset using VADIS vehicle communication.
Resetting the Service reminder indicator (SRI), model years -2001
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The lamp remains lit for 120 seconds when the ignition is switched on.
Note! If the lamp flashes, it may be because one of the service parameters has not been programmed.
Proceed as follows to reset the service reminder indicator (SRI):
-Ignition position I
-Press and hold in the reset button for the trip odometer
-Ignition position II
-The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
-Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
Note! If the trip meter reset button is not released within 5 seconds the indicator is not reset. However the indicator will stop flashing.
Resetting the service reminder indicator (SRI), model years 2002
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The text message is displayed for 120 seconds each time the ignition is switched on.
-Ignition position II.
Note! Turn the key to position II within 2 seconds. -Hold the reset button for the trip meter pressed in until the original value has been reset. Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released. -Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded -If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds. Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
brutus
I have a similar probelm with my 1999 S-80 2.9 136000miles. The "Engine System Service Required" indicator came on. The mechanic said no service codes were on. I went throught reset sequence and it went off for a while but then came back on.
What does this messge mean and am I going the right directionto have it turned off or reset?
ddrewyor
10-31-2010 07:48 AM
