2008 wheel swap
2008 wheel swap
Howdy,
I just picked up a 08 s80 3.2. Not a fan of the wheels. I came across a set of Ford focus st wheels that I like. Here are the stats. Will the Ford wheels fit? Has anyone done this yet? It's a 2.5 hour drive so I'm trying to be sure they fit before I go get them.
Volvo wheels
17x7
5x108
50mm offset
63.4 bore
Ford st wheels
18x8
5x108
55 mm offset
63.4 bore
Volvo wheels
17x7
5x108
50mm offset
63.4 bore
Ford st wheels
18x8
5x108
55 mm offset
63.4 bore
There is a slight chance of an issue due to the different offset, depending on what tires you're running, and a chance of rubbing when steering is at full lock (turned all the way) one direction or the other. On the standard (not variable - no 4C) rack there are stops you can snap in, under the rack boots (the OE rack is Visteon and was installed with different tie rods on some Ford Mustang and other cars) to reduce the steering angle and stop the rubbing if needed. If you're not tearing into it yourself, a mechanic with some awareness of the rack (not a fitter) can fix that without much fuss, or you can yourself if you want to slip the rack boots a bit and resecure them.
Ducati900 (04-30-2024)
