Cost estimate for valve job after timing belt slip
Old 11-11-2007, 03:55 PM
S80_Pilot's Avatar
Default Cost estimate for valve job after timing belt slip
Timing belt tensioner pulley failed and the belt slipped.Now I have bent valves. What price should I expect at a Volvo specialty shop to fix the bent valves? Here's the history. Car was running smoothly until just before I shut it down while pulling off the road at 10 mph. Volvo dealer R&R'd the tensioner pulley and installed a new belt,idler roller, and belt protector ($1100) to see if the valves survived w/o damage. No such luck, and the dearler wants an estimated $3500 more to fix the engine. 2000 S80 T6has 103k miles. Oh well, my usual luck with this POS S-80. Thanks,
George
Old 11-11-2007, 06:49 PM
Default RE: Cost estimate for valve job after timing belt slip
I would say somewhere close to $2500.00 to $3000.00.
Old 11-11-2007, 07:44 PM
I have an estimate from four days ago from a local dealer: valves, assorted rings and gaskets, and 14 fairly expensive 'screws'. Roughly $3,800, divided almost equally between parts and labor.
Old 11-12-2007, 09:29 PM
gordon368's Avatar
wouldnt it be a lot cheaper to put a new "used" engine in?
Old 11-13-2007, 05:37 PM
Not really thats more like $6000.00
Old 11-14-2007, 05:28 PM
I replaced my engine for $2,200.00 (it was $3,000 by the time it left the shop, but that included new timingbelt, tensioners, water pump, radiatorand replacing all the oil seas - oil pan, oil trap, turbo lines, etc). I picked up an engine with 40K miles for $1500 (plus $700 labor). This was after the dealer quoted me $2,700.00 to fix a burnt valve. After the fact, they told me I could have just bought a new cylinder head from them with valves, etc. for $1,200.00. After spending around $5K on my 99 S80 T6 over the past 3 months or so, I have learned you can negotiate a lot with the stealers (dealers) and they will drop prices. i.e., 2 diagnostics reduced from $98.00 to $50.00, lower strut mounts from $48/ea to $30/ea, 3 coils from $67/ea to $35/ea and the last coil down to $25.00. Speak your mind and remind them that their poor workmanship is costing YOU a ton of hard-earned money. Good luck.
Old 11-16-2007, 12:35 PM
S70_Driver's Avatar
ORIGINAL: EuroDriverSD
Yes, when the pistons hit the valves, the pistons are normally fine,but the more lightly constructed valves are mashed. Soif you're replacing whole components, you would need only the cylinder head,not the head plus engine block replaced. The head will be considerably cheaper in both parts and labor than an entire engine.
Old 11-20-2007, 08:28 PM
im replacing piston rings,valve stem seals,water pump,timing belt,tention pulley,idle pulley,spurk plugs,gaskets,head gasket,14 head bolts,clean whole motor inside, everythink cost me under $1,000 labor is free because i'm doing everythink my self, i did few japanise cars so i'm not stranger to this, will post pics soon shop or dealer want to much money
Old 11-25-2007, 03:53 PM
S80_Pilot's Avatar
Thanks for everyone's suggestions. I'm going the cylinder head replacement route vice a used engine, and doing most of the work myself. Local dealer wanted $4200 for installing a used engine with 69k miles on it.
Old 01-26-2008, 04:58 AM
nicolaselias's Avatar
All this talk of timing belt and tensioner issues has me a bit edgy.. I bought my s80 as a great deal with 97,000 miles.... now im just over 100,000 miles 5 months later and im genuinely worried about the timing belt. I planned to hold off for the reccomended 105,000 miles but is this reccomended... I dont know if it makes a difference, but im a 'spirited' driver to say the least hahah
Old 01-28-2008, 04:31 PM
nicolaselias,
Consider yourself extremely lucky. I've found Volvo specialty shops that will do the t belt, tesioner, water pump, and idler for $500 bucks. I waited to 90,000 miles and am now faced with engine/ valve assembly replacement, way more costly that the timing belt service. DO IT Immediately!!
Old 01-28-2008, 04:47 PM
Eurodriversd said he could get a new cylinder head with valves, etc. for $1,200.00.
How much would labor be to install the new head with valves?
Old 01-31-2008, 08:12 PM
ORIGINAL: nicolaselias
I replaced mine at 67,000 miles on my 2000 Volvo S80. The mechanic said that my belt looked great but at 8 years old I figured I'm not out anything to get it done prior to catastrophic failure. Too many horror stories had me on edge too. It costs you a few bucks but the peace of mind is well worth it.
Old 01-31-2008, 11:34 PM
Ok, now im really terrified.. I cant do the work on the belt until atleast 10 days from today... I have a crazy schedule coming up and I wanted to let everything be done on the car at once when the time came, not to keep splitting it.. The mechanic is about 15 or 20 mins from me and the dealer is about 30 So i want to make as few trips as is possible..
The thing is, for all I know the belt could have been changed by the previous owner as it appears he took realtively decent care of the car... I got the car from a dealer but i have alot of his bills and so on from the car... i searched for him on the county sheriffs dept website, and apparently he had a DUI, then was caught driving the s80 without a license... hence the reason he sold it/was repod... i guess the latter...
Anway, i still wanted to get the mech to take a look at it..
Where would I be able to get the pulleys, tensioners and the belt at the best price? Assistance will be apreciated.
Thanks
If it comes to it, I can always take the drive up to orlando to visit Tech's place and let him do it depending on how things are looking...
I wonder whats the cost from him.. hmm
I dont really know any volvo specialists in tampa, even though there have to be some..
Old 02-01-2008, 05:42 AM
Any of you (namely tech or anyone in florida) ever heard of a Volvo speciality shop in tampa named Mike's Automotiove? From what im seeing, its the only actual volvo specialty shop.. Im thinking to give them a call to get a reasonable estimate on jobs such as the timing belt and so on...
I doubt they will be able to do the software upgrades I need so I guess il have to once again find myself at the dealer..
Old 02-01-2008, 06:20 AM
I also found another speciality place, not so much a volvo place but its called Ludek's European Cars in south tampa... apparently specialise in all european brands inc volvo... if you heard anything of the 2, let me know..
  #17
Old 02-01-2008, 06:53 PM
Sorry but never heard of them.
  #18
Old 02-06-2008, 12:30 PM
Im now thinking of it, is it just that volvos have a tendency for the timing belt and associated parts to go bad, or was I just extremely lucky with my accord? We did over 150,000 miles on that car before changing the belt and pulleys and so on, and we didnt actually need to, was just a precautionary measure. Iv seen sites where i can gt all the parts for the timing belt job for under 150, ... how much should labour add to that?
Thanks
  #19
Old 02-06-2008, 08:02 PM
Labor is I believe 3 to 4 hours depending on turbo or non turbo cars.
  #20
Old 02-07-2008, 12:30 AM
Well its something il look into ASAP.. At least to get it checked to see the condition of the belt.. I suspect my serpentine belt needs changing also, im seeing some small cuts and fraying in it but nothing too too serious as yet... Anyway, thanks for all the help and adivce so far... one last thing, if im doing the timing belt work, il need the belt, the pulley, the tensioner... anything else?
Quick Reply: Cost estimate for valve job after timing belt slip
