cutting brake rotors, question for you Tech
Old 10-22-2008, 08:21 PM
team's Avatar
Default cutting brake rotors, question for you Tech
Ok, i have an on car brake lathe and I have some pulsation so I am going to turn my rotors. I have the specs for runout and min. thickness and I will check my runoutbefore I do it. But I have read on here that you shouldn 't turn the rotors. Has anyone actually turned the rotors and witnessed the results, or is this just a way for the dealer to get more money and require new rotors?
Old 10-23-2008, 08:33 AM
BILL_MCCASSEY's Avatar
Default RE: cutting brake rotors, question for you Tech
Don't waste you time cutting them. They are already warped. If you cut them they lose density and will not handle the heat as well an will probablly warp again very soon.
Old 10-23-2008, 09:27 AM
Agreed Volvo's hate to have the rotors cut.
Old 10-23-2008, 09:48 AM
nicolaselias's Avatar
Completely off topic, but yesterday was the first time i really had to do do a quick response emergency braking situation and the s80, and WOW those brakes hold up well.. I felt the ABS pulsing away at my foot but sure enough I stopped before smashing the back of the woman's Accord. Feels good to know I have such a good car helping keep me safe..
do you know if the rotors on the car right now are OEM or aftermarket?
Old 10-23-2008, 10:37 AM
team's Avatar
I guess I will go ahead and turn them. It won't cost anything if Ido it and i will get to witness the outcome. At the worse I will have to buy rotors that iprobably willhave to buy anyway.
I will post the outcome good or bad for everybody.
Old 10-25-2008, 05:57 PM
gordon368's Avatar
yeah the s80 has hella strong brakes. Isnt the s80 have a Overdrive thing where in strong cases of pressing the brakes it will put even more power the brakes?
Old 10-26-2008, 07:57 AM
Not that I am aware of.
Old 10-28-2008, 10:07 AM
75ohm's Avatar
Rotors are fairly cheap...
Old 10-28-2008, 10:50 AM
Crito's Avatar
Banned
Stock S80's rotors are pretty thick, so I doubt they've warped. Should be no problem shaving them down a bit.
adamsrotors
39
06-25-2015 01:01 PM
adamsrotors
49
06-25-2015 12:58 PM
Grendel
10-19-2010 12:54 PM
stepwilk
03-21-2009 01:11 PM
team
02-02-2008 09:54 AM
Quick Reply: cutting brake rotors, question for you Tech
