faulty usb replace
faulty usb replace
hi
I need some help 2015 xc60 uk. the usb socket isn't working ,I tried to update the sat nav and it doesn't see a usb nor will it charge a phone when plugged in. also the little black plastic thing that surrounds the brass fingers has come out.
So if its faulty any ideas how I get it out without breaking all the plastics .
thanks
thanks
hi
I need some help 2015 xc60 uk. the usb socket isn't working ,I tried to update the sat nav and it doesn't see a usb nor will it charge a phone when plugged in. also the little black plastic thing that surrounds the brass fingers has come out. So if its faulty any ideas how I get it out without breaking all the plastics .
Have you tried to looking at the fuse to see if it is blown?
Also, buy some CRC electronics cleaner and clean the area well.
[QUOTE=iamspuddy;510685]is there no fuse for this?
Also how do I get to the bottom to replace it without breaking anything[QUOTE]
You said it was physically broken, and does any usb device have a fuse?
You take the console apart to get the old one out and the new one in. If you don't have the proper tools or skills you might want to get a garage to do it for you.
skills no problem , but when you can't see any screws and dont know which bits to pull as you dont know where the pop out bits are ,I could do with some guidance...I will buy a new part and the fuse comment was mentioned from a previous contributor which suggested there was a fuse . thanks
hi
thanks
thanks
have you managed to replace the socket? And it works well? My wifey just broke it in our xc60… . I also have to replace it.
Diesel
04-11-2015 04:46 AM
